Labview Web Server Problem
I have made my application and build it, but then the .snap?
and .monitor? options of the web server doesn't work. Do you know why?
Message 1 of 8
(5,621 Views)
Go into the preferences of the built application and check the web server
settings.
The Web Server must be enabled. LabVIEW must not be running at the same time
with its Web Server enabled at the same port. In "Visible VIs" you must
provide a list of VIs that can be accessed. Enter * to access all.
If your application does not have the preference menu enabled, copy from the
labview.ini file the web related items to your app.ini file.
You can also use the application Web Server property nodes to set the
properties at run-time.
Jean-Pierre Drolet
Francisco Picatto a écrit dans le message :
39874bf0@newsgroups.ni.com...
Message 2 of 8
(5,621 Views)
Thank you very much for your answer, but I have already done that. My server is
working, but the snap and monitor don't...
Thanks anyway
> settings.
> Regards,
> Jean-Pierre
Drolet
Message 3 of 8
(5,621 Views)
Did you check that the VIs front panels have been saved with (or removed
from) the built application? They have been obviously saved if you can open
the front panels in the built application but otherwise you have to check in
the VI built settings in the application builder, "Remove Panel" case.
Does the Web Server work to browse other files?
a écrit dans le message news:
39888344.D996B99D@com.uncor.edu...
server is
> Thanks anyway
server
> > settings.
time
the
> > Regards,
> > Jean-Pierre Drolet
Message 4 of 8
(5,621 Views)
The web server browse ok, (I aready know that it has some problems with Intenet
Explorer, so I proved with Nescape 4.7), the problem is with snap and monitor..
It seems like some library wasn't copied...
I didn't remove a panel in the remove panel case...
edu...
> server is
> > Thanks anyway
> server
> > > settings.
> time
> the
> > > Regards,
> > > Jean-Pierre Drolet
Message 5 of 8
(5,621 Views)
You must include lvpng.dll and lvjpeg.dll from the RESOURCE directory in the
application directory
If you already did, I give up... 😞
a �crit dans le message news:
3988B1C5.F7598A86@com.uncor.edu...
Intenet
monitor..
> Thanks
open
check in
> > server is
> > > Thanks anyway
> > server
> > > > settings.
same
> > time
must
from
> > the
the
> > > > Regards,
> > > > Jean-Pierre Drolet
> > > > Francisco Picatto a �crit dans le message :
why?
Message 6 of 8
(5,621 Views)
Yhea, I did it, I put those files everywhere!!!....
Thank you very much for your time
See you
Francisco Picatto
> Intenet
> monitor..
> > Thanks
> open
> check in
> > > server is
> > > > Thanks anyway
> > > server
> > > > > settings.
> same
> > > time
> must
> from
> > > the
> the
> > > > > Regards,
> > > > > Jean-Pierre Drolet
> why?
Message 7 of 8
(5,621 Views)
I got my to work just now.
First I created the exact same path to the www directory on the machine where I was running the executables.  On the build machine that was
"C:\Program Files\National Instruments\LabVIEW 8.6\www" so I made this directory and put the html files in there.
Then I created the directory for the log files:
"D:/Program Files/National Instruments/LabVIEW 8.6/resource/webserver/logs/"
Then I edited niwebserver.conf and put the path to the www directory on the line that was
DocumentRoot "./../../www"
to
DocumentRoot "C:\Program Files\National Instruments\LabVIEW 8.6\www"
and above that line I changed the line for
CustomLog "whatever"
to
CustomLog "D:/Program Files/National Instruments/LabVIEW 8.6/resource/webserver/logs/:
Then I stoped and restarted the .exe file.
I opened IE and typed in http://machine.name.with.corporate.domine.and.all.that./Executable.htm
Shezam!
Message 8 of 8
(4,959 Views)
