Labview& NI ELVIS
Hi to all,
   I connect 1-phase supply to a diode bride full wave rectifier with R-L load
through voltage sensor(LV-25P) and current sensor(LA-100p).   I take the source
voltage and source current and connected to analog channels of NI ELVIS.
Through NI ELVIS device Iam able to see the waveforms in Labview. I use normal
labview but not Labview real time.
Then  I use transport delay block  to delay the waveform by 90 degrees but I am
not getting the delayed waveform.
I am attaching the circuit , please go through it & tell me what i have to done
to delay the signal which I has taken  through NI ELVIS.
Finally Is it possible  to find out  the harmonics in the source current which
i has taken through ni ELVIS if i build the control circuit  either in normal
Labview???? or  in Laabview Real time???
Waiting for reply.
Thnks in advance
(3,280 Views)
Good it wanted to know since I can make move an engine using labview and N I ELVIS
(3,076 Views)
