Labview and Arduino
Hello All,
I want to collect data from arduino and plot it using Labview Interface. Also I have to collect data from Arduino's multiple analog input. I done Labview program for single analog input using VISA. But pls let me know whether VISA can be used in reading multiple analog inputs in labview.
Regards
(3,664 Views)
Combine multiple values into a single string to send from the Arduino code.  How does the data look?  Is is ASCII?  Just send the values separated by commas and break it apart in LabVIEW.
(3,651 Views)
You could also have a look at the LINX toolkit which is designed for talking to an Arduino from LabVIEW: https://www.labviewmakerhub.com/doku.php?id=libraries:linx:start
(blog)
(3,621 Views)
