Labview and CANoe Standalone Manager interface
I want to send data from LAbVIEW to a Vector device. I do not have CANoe installed on my PC instead I have Vector Standalone Manager for CANoe.
Is it possible to send data from LabVIEW to Vector device through CANoe Standalone Manager and read it back?
(4,639 Views)
unfortunately i could not find any information on this. Maybe you can check the following post:
http://forums.ni.com/t5/LabVIEW/from-CANoe-to-LabVIEW/m-p/2736215
(4,587 Views)
Firstly thank you for your help. But I have already seen that link and its not very useful in this case. I will try to get some help from Vector support.
Thank you.
(4,561 Views)
Did you see this library?
https://decibel.ni.com/content/docs/DOC-30180
I use it to write/read CAN and LIN from CANcaseXL.
(4,536 Views)
Unfortunately there are no free CANoe Dlls available on vector website 😞
(4,494 Views)
Why do you need to use CANoe to send and receive data through a vector device? You haven't described the problem enough.
(4,483 Views)
teju_18 wrote: Unfortunately there are no free CANoe Dlls available on vector website 😞
There are no free CANoe dlls on the Vector website but there is a free driver library that you can use to talk directly to the hardware bypassing the need for a CANoe license altogether.
See this NI community document here: Vector XL Driver - LabVIEW wrappers
Failing that, doesn't CANoe install with an ActiveX inteface?
Troy - CLD "If a hammer is the only tool you have, everything starts to look like a nail." ~ Maslow/Kaplan - Law of the instrument
(4,367 Views)
