Labview and Excel
I want to read a Excel Spreadsheet into Labview without having any idea
how big the spreadsheet is.
I know the 'LastCell' variable in VBA, but can't get it working in
labview using this varible in the 'special cel' method.
Can anyone help me?
Sent via Deja.com http://www.deja.com/
Before you buy.
(3,363 Views)
You should use "UsedRange". In my Version of Excel, LastCell doesn't exist.
(3,363 Views)
Vincent Hottier wrote:
>>I know the 'LastCell' variable in VBA, but can't get it working in>>labview
using this varible in the 'special cel' method.>>>You should use "UsedRange".
In my Version of Excel, LastCell doesn't exist.>>>
The easiest fix is to place key words (you'll need 3) on the borders of
your data
then search for them and then parse your Sheet. This saves a lot of headaches
without having to get fancy with VB
(3,363 Views)
