Labview and Manchester Encoding
Does anyone have a solution to how one can convert binary input to manchester
encoded output?
(5,849 Views)
In manchester encoding a bit is represented by a rising or faling edge rather than a high or low.
a low or false value is represented by a falling edge (true to false)
a high or true value is represented by a rising edge (false to true).
Hence:
1 0 1 0 1 1 0 0=
01 10 01 10 01 01 10
If your input comes in as a binary array, you need to replace every ellement with the corresponding two elements.
Note that for a particular output baudrate, your clock must be twice that frequency.
Amaury R,
NI Applications Engineer.
(5,849 Views)
I need to perform Manchester Encoding on a bitstream that I will loading into an ARB to be transmitted using CPFSK, is there anything available in NI's Modulation Toolkit to help do this?
(4,318 Views)
Dude!
You've just managed to bump a 15 year old thread!  That's gotta be some kind of record!  Don't be afraid to start your own thread.
The example finder will be your friend!  I don't have the Modulation toolkit installed but, there are examples that demonstrate phase contineous frequency shift keying that require the Modulation Toolkit.  A evaluation version is available so you can try before you buy.
(4,311 Views)
Lol, thx Jeff. I found an example.
(4,303 Views)
