Labview and Matlab
Hi
I'm using labview 6.i and Matlab R13
I 'm currently trying to use a script matlab in a vi and it doesn't function
My script Matlab is very simple :
I define one exit variable S and in the script, I put the value of s to a
numerical value e.g. 1
The Vi seems to be OK (no error in compilation) et nevertheless, if I look
at the value of S, the vi give 0
Any idea about it ? Can it be a problem of compatibility between the version
of Labview and of Matlab that I am using ?
Many thanks
Fabrice
(3,072 Views)
Matlab R13 is 6.5. Is that correct? I cannot remember how then do the version number in LabVIEW. I will direct you to a KnowledgeBase on the NI web site. I think it holds the answer to your question.
http://digital.ni.com/public.nsf/3efedde4322fef19862567740067f3cc/ce309627064a3d5686256a9c005b0a5f?OpenDocument
(3,072 Views)
I have replaced the matscipt.dll by a new version that is compatible with my
version of Labview
and now it's OK
Regards
"blimpie boy" a écrit dans le message news:
506500000005000000BDDD0000-1042324653000@exchange.ni.com...
(3,072 Views)
