03-11-2021 05:07 PM
I installed NI MAX and then Labview, my goal is to use the NI software to measure temperature with some thermocouples. I was not able to find the "DAQ Assist" command found in the example below. I read on your website that I needed to install Labview THEN NI MAX. So I uninstalled NI MAX and when I try to reinstall it, it looks like it is still installed and won't let me continue after selecting which software.
03-11-2021 05:28 PM
I assume you installed the NI-DAQmx device drivers as well?
03-11-2021 07:33 PM
Have you (ever) successfully installed LabVIEW? You seemed to say that you installed MAX before installing LabVIEW. If this is true, please try to find a knowledgable student, colleague, anyone to undo what you've done and do a proper LabVIEW installation for you. LabVIEW installation can be a bit of a challenge, and NI hasn't made it any easier with NIPM ...
Bob Schor
