Labview and Visual C++ 6.0
Howdy,
I need to send data from a Visual C++ application to Labview over a
tcp/ip network. How do I do it? Are there any examples to study out
there?
M Soderberg
Sent via Deja.com http://www.deja.com/
Share what you know. Learn what you don't.
(4,266 Views)
seplusplus@hotmail.com wrote in message <7n9bhq$id0$1@nnrp1.deja.com>...
>Howdy,
>there?
>Thanks,
>M Soderberg
Buried deep in the examples on the MSDN Library disk 1 that comes with VC++
6.0 is code for simple TCP and UDP server/client apps. Not a straight
example of comms between VC++ and LabVIEW but it will give you the basis for
such. At least I hope so :-}
If you're interested run MSDN and under the contents window go down this
tree
MSDN Library Visual Studio 6.0
-Visual C++ Documentation
-Samples
-SDK Samp
les
-Internet Samples
-NetDS Samples
-Winsock: Windows Sockets Samples
-Simple
Cheers,
Ed Hutchinson
GNS Ltd, New Zealand.
(4,266 Views)
One word: DataSocket
Go to http://www.natinst.com/datasocket/ for more info. It's easy and painless.
Carl Nybro
NI
> >Howdy,
> >there?
> >Thanks,
> >M Soderberg
> such. At least I
hope so :-}
> tree
> -Samples
> -SDK Samples
> -Internet Samples
> -NetDS Samples
> -Simple
> Cheers,
> Ed Hutchinson
(4,265 Views)
For those who are looking for a good example on VC++ for TCP:
Mfcsocs.exe sample demonstrates how to communicate in a TCP connection in Visual C++
http://support.microsoft.com/kb/185728/en-us
regards
Dalia
Dalia Russek
Senior Technical Support Engineer
National Instruments ISRAEL Ltd
(3,982 Views)
