Labview and operating system
I want to distribute an application developed in Labview 8.0, and I want it to run on windows 98 or windows nt, is this possible?. If not, will I have the same problem with Labview 7.1?
(3,028 Views)
LabVIEW 8 supports only 2000 and XP, so you can't do it.
7.1 supports NT, so you should be able to convert back to 7.1 for that.
For 98, you will need 7.0.
___________________
Try to take over the world!
(3,013 Views)
LabVIEW 8 does not support 98 or NT. LabVIEW 7.1 does not support 98.
(3,011 Views)
