Labview appl. Builder 5.0
when i start my application in the development-system, it runs endless, it
stops only if i want. When i build an application with the application
builder 5.0, my application runs only once, or stops. What can i do to run
my builded application repeated.
Holger Decker
(3,411 Views)
"Holger Decker" writes:
> Hello,
Setting the default value to true of the while loop boolean before
compiling?
(3,411 Views)
Sure. When the program jumps from one VI to the next VI and the back to the
first VI, it stopps. Because the first VI has stopped.
Holger Decker
(3,411 Views)
Did you try the "RUN REENTRANT" button in the execution options?
(3,411 Views)
