Labview application built under Labview Windows and Linux.
Is it possible to run an Labview applications built under Windows, under Linux with only the Linux run-time?
S. Maury
Responsable Technique
Technical Manager
(4,157 Views)
No. You have to re-build it. The binaries for windows, linux, Mac, etc., are all different.
(4,151 Views)
Thank you Dennis for your answer.
If I understand, If we want to export our Labview application from Labview Windows to Linux, Mac Os,.... We need to buy Labview with application builder under each system.
Smiley Sad I thing NI need to thing to create an multi platform Apps builder.
S. Maury
Technical Manager
(4,144 Views)
This request has been made many times before as the problem has been discussed numerous times on this forum. I would suggest you go to the product suggestion center at http://digital.ni.com/applications/psc.nsf/default?OpenForm&temp1=&node= and submit it again.
(4,142 Views)
Thank you Dennis. It is done, one suggestion more on this direction....
Regards.
S. Maury
Technical Manager
(4,136 Views)
Regards.
Unfortunately it is not as simple as throwing together the application builder code of all platforms into one piece of software. Some things need certain support from the underlying platform too and that would mean NI would have to provide emulation/simulation or whatever of certain platform features to be able to build for instance a Linux executable on a non-Linux system.
Rolf Kalbermatter
Rolf Kalbermatter  My Blog
(4,131 Views)
Thank you rolfk,
I understand now that is not only a problem of files generation. But also a problem of instruction and compatibility between all systems.
Thank you for your ligth in this point. I will ask my NI supplier to provide me an evaluation software under Linux.
Brest regards.
S. Maury
Technical Manager
(4,106 Views)
