Labview block diagram - help with Event structure
Dear community,
I am having problem running my labview program due to the event structure VI that i have implemented for locking numeric slider to not change values by mistake. but as i also have DAQ in my same block diagram. it is showing an error. How can i rectify this mistake ? I am also attaching a picture of block diagram as well as the error dialogue.
My logic is that if i change the value of the numeric slider. there should be a dialogue box asking "are you sure you want to change the value?". and only when i click yes it should change or else it should go to the previous value. Kindly help me fix this error.
I have tried fixing number of samples and increasing the size of number of samples and sampling rate also. What could be the possible error ?
Shruthi
(1,688 Views)
Don't sample in the same loop.
Qestit Systems
Certified-LabVIEW-Developer
(1,679 Views)
Hi shru,
Yamaeda is right.
Other items:
  • Don't use a wait in parallel to your DAQmxRead operation. The DAQmxRead should control the iteration rate of your loop!
  • An event should be executed as fast as possible. Calling a Dialog function inside the event is the opposite of "as fast as possible"!
  • Handling "value change" events of knobs can be quite tricky as they tend to initiate a lot of events when you move the knob. In recent LabVIEW versions you could limit the event queue size to circumvent/minimize problems from this…
  • You might think about using the timeout event so the event structure does not block the loop from iterating…
But again: separate DAQ handling from UI handling!
(1,670 Views)
Thanks a lot for the timely reply. I seperated into 2 while loops and now my numeric slider is working perfectly.
But i also have one more doubt. what is the best way to collect these data from NI DAQ USB 6009 to excel. i tried using "Set dynamic data" and "write to measurement file" VI's but the same error from my previous screenshot seems to appear. How can i fix that ?
Thanks and regards,
Shruthi
(1,642 Views)
I much prefer to use the DAQmx Configure Logging to have DAQmx save the data straight to a TDMS file. This is extremely efficient. Assuming you have the TDMS Excel plugin installed, Excell can just open up the TDMS file.
(1,631 Views)
  • The "error" is in your program logic.  Value change events should never contain any user interactive code.
  • That song and dance with the control reference and value property node is completely pointless and would only make limited sense if the event has value change event for multiple controls of the same datatype (But even then, done right there are better ways). A local variable would be perfectly sufficient.
  • Yes, any value change control for sliders should be have an event queue of 1 and not lock the panel.
(1,603 Views)
