Labview cDAQ NI 9775 High-resolution meas acces
We started using de 4ch NI-9775  cDAQ and we are very happy with the results so far.
In the general info on the NI website it is mentioned that there are two timing modes for this cDAQ
High Speed measurements and High Resolution measurements.
We want to compare these two modes for usage in our lab in Brussels.
Typically we are measuring 1MS/s per channel for about 5000 samples per channel.
Typically this is a pressure meas with a Kistler sensor and the peak output voltage is 3,5 volts.
How can we access these two modes in the labview code ?
Thanks !!!
Alain V
(1,174 Views)
This article describes how to - https://knowledge.ni.com/KnowledgeArticleDetails?id=kA03q000000YHjCCAW&l=en-US
Santhosh
Soliton Technologies
(1,147 Views)
Accepted by topic author Alain_V
Thanks !!
I found how to do it and on our NI 9775 it works.
A note to readers .... you have to connect to your cDAQ in order to find this property node !!
Thanks !!
Alain V
(1,133 Views)
