Labview calculator
I need a calculator type display so that when I type a number from a keypad
(like a phone) the number goes into a display and scrolls along. Any ideas?
Tom
(10,715 Views)
"Country Loon" wrote in message
news:1099091412.326623@ftpsrv1...
keypad
ideas?
> Tom
Actually I figured out how to do this - for anybody who is interested by
using concatenate strings and registers.
Tom
(10,714 Views)
In the Express VIs (LabVIEW 7.0 and later) there is a Formula Express VI. It has a calculator interface. you might be able to use it as is. If not, you can open the configuration VI for it and see how NI did it. This VI is on the functions palette at Express -> Arithmentic & Comparison -> Formula. The configuration VI is at LabVIEW\vi.lib\express\express arith-compare\FormulaConfig\Configure Formula.vi .
It basically uses a while loop with an event structure. It has buttons that you can press with a mouse, or you can just type into the display. The result is sent into a formula node.
I hope that this helps,
Bob Young
(10,714 Views)
Here is a nice calculator example built in LabVIEW.  You will need LabVIEW 8.5 to view it.  Check it out!
Erik J.
(10,309 Views)
Hai,
This calculator vi is facing some problem to open. I have attached the error code. Kindly do the needful.
Mathan
(10,125 Views)
Hi mathan,
It looks like you edited a subvi and you just need to right click on it and select re-link to sub vi.
Jim
LV 2020
(10,122 Views)
Hai,
Am sorry. Actually i opened it directly from zip file. That's why i got that problem. But now after extracting the zip file into a folder, everything works fine now. Great work in building that calculator.
Thanks for the support,
Mathan
(10,111 Views)
