Labview calls command line
When using System Exec.VI to perform the operations of command line,It can be executed correctly, but the execution process cannot be seen and only jumps out of the black window.The execution information can only be seen on the output terminal of VI after the execution is completed.May I ask how to display the execution process in real-time in the black window that pops up?
(2,669 Views)
Hi wuyaning,
That black window is a command shell window…
When there should be some text/ASCII art to be displayed then the called executable has to provide that.
Which executable do you call? Can you change the behaviour of that EXE, either by command line arguments or by comppiling its source code?
(2,633 Views)
By not waiting for the program to complete. Then the IO streams for the console are not hooked. However:
- you now don’t know in LabVIEW when that script/external program finished
- if the script executes quickly it will close the console window before you had time to read it. You could fix that by waiting for a keystroke at the end of the script.
Rolf Kalbermatter  My Blog
(2,632 Views)
Accepted by topic author wuyaning222
If your EXE does send data to stdout while running, then one of these might help:
https://www.vipm.io/package/jki_lib_dotnet_system_exec/
https://labvolution.com/labview-system-exec-callbacks/
___________________
Try to take over the world!
(2,623 Views)
Thank you for your reply. Set false to the terminal of waiting for run ,the execution process can be displayed on the  window ,but labview is unable to get contents of  the window。Is there any other way?
(2,560 Views)
Did you look at the links I posted?
___________________
(2,523 Views)
Sorry for the late reply,I downloaded the package and can now obtain the output. Thank you very much
(2,505 Views)
