Labview can't connect OPC Server
Hİ everyone my deveploment pc works properly its run without any problem I can write and read data from opc,but deployment pc I checked Quick Client and opc server works properly but when I started the exe After deploying the library with the I/O Server, variables return no known value at DSC, I don't know what I missed everythings works fine.
I am waiting your's valuable comments.
System
NI OPC Server 2016
Labview 2017
I have these license
NI OPC Server
OPC UA Deployment
(3,654 Views)
I checked the event wiever and when I started the exe event wiever gives error ralated with NI variable engine
Description of Event ID 0 in NI Variable Engine cannot be found. The component that started this event is not installed on your local computer, or the installation is corrupted. You can install the component on the local computer or repair it if it is installed. If the event was started from another computer, the display information should have been recorded with the event.
I attached the error
How can I resolve this error
(3,525 Views)
Hello Honour20
Have you seen this article?
__________________________________________
The best way to thank, is to give KUDOS
(2,407 Views)
