Labview code
Hello everybody
I am new here and seeking some help, actually I am looking for a Labview program to move a laser in 2D with translation stages and the same time record the signals from the detector, I was not really required to do this part as I have to do something else with the data collected but somehow I am also now have to do this part and the time is very short i have not used labview before so if anyone can provide me with the program that will be highly appreciated.
Thanking you all in advance
(3,136 Views)
If you are looking to hire someone to do this work, you should post to the Job Openings board. By your description, there would be a lot of custom code required and it's not at all likely that you will find an existing program.
(3,121 Views)
