Labview connection with HW
Yes, that could be a solution. Do you have any advice or tips on how to proceed in this case?
Regarding measurement cards, there is also the possibility of using USB-6003, USB-6002 or USB-6009 for me. However, I think it would be the same problem as you said before.
Thank you,
Daniel
Message 11 of 13
(599 Views)
Hi Dan,
Yes, the same problem as they are basically the same simple DAQ device…
Message 12 of 13
(595 Views)
@dan23 wrote:
I think ADS1293 is able to communicate by UART as well. Maybe there is some way how to do it.
The data sheet mentions nothing about UART, at least that I could find.  I would still go back to the USB-8451 that I linked to before.  If I knew Arduinos better, I might go that route as well, but a RS-232 is usually a lot slower than SPI, so you could have data buffer issues there.
Message 13 of 13
(586 Views)
