Labview control LCD by PC parallel port
Thanks Dennis Knutson very much!
Before, I don't thinks we can use more I/O ports in a program. I'll do follow your idea, when it complete I'll say to you.
Members in there are fervour.Dear!
Message 11 of 21
(1,834 Views)
Dennis Knutson wrote:
Here's something quick and dirty. Since there are separate registers for the parallel port and you have wired the data register to the data inputs of the lcd and 2 of the control register pins for the E and RS, it made things a bit simpler.
I did not do anything about the instruction data to set the lcd into the mode you want. You can modify the data write VI and change the RS level to 0.
Hi Dennis
Nice just as I would done I myself. But is not some of the bits in register address base+2 inverted by hardware in the port? This mean you have to write in "0" to get high output. See my compiled list. You should check this out aludlak. It is important 😉
BASE ADDRESS + 2     (PCR) Control register (Read or Write)
Bit 0  Pin 1  DATA STROBE Output         Inverted
Bit 1  Pin 14 AUTO LINE FEED Output    inverted
Bit 2  Pin 16 INITIALIZE PRINTER Output
Bit 3  Pin 17 SELECT INPUT Output        inverted
Bit 4  0 = disable interrupt, 1 = enable interrupt
Bit 5
Bit 6
Bit 7
Besides which, my opinion is that Express VIs Carthage must be destroyed deleted
(Sorry no Labview "brag list" so far)
Message 12 of 21
(1,814 Views)
:Thanks Cop rouge!Smiley Happy
I saw your compiled list. It really useful for me.
I still doing with this, I imagined the way have to do with it, but now it not yet complete.Smiley Sad possibly my knowledge about Labview so limit.
Message Edited by aludlak on 04-25-2009 08:22 AM
Message 13 of 21
(1,800 Views)
Hi, everyone!
I written initializing the LCD.But when I run it, I don't see any changeon my LCD. ah, while writting(chang the program) I saw 1 times the surcor on LCD but I don't know why, and now I can't see it again. Wold you please see again my test. Smiley Sad
Message Edited by aludlak on 04-25-2009 09:57 PM
Message Edited by aludlak on 04-25-2009 10:01 PM
Message 14 of 21
(1,775 Views)
I have made some small modifications. All 8 bit constants and controls do now have binary display. I have also left some work for you ;). You may run this VI standalone. I have set the default value for the data control to be the display on command.
Good luck
Message 15 of 21
(1,758 Views)
Hic, my Labview v8.5 can't read your program labview 8.6.Now I have to downd v8.6 demo^^. Thaks you Cop rouge.
Message Edited by aludlak on 04-26-2009 03:43 AM
Message 16 of 21
(1,756 Views)
Ok in 8.0
Message 17 of 21
(1,753 Views)
I changed your subvi in to my program. but LCD still don't have any change. I conected E with 14 pin, it mean when E =0, RS=0 => bit 1 =1, bit 2 =0 (b10). don't understand it wrong where.
This Instruction I did follow your program Cop rouge. Would you please see again.
Message Edited by aludlak on 04-26-2009 04:31 AM
Message 18 of 21
(1,740 Views)
Accepted by topic author aludlak
Your method is correct at least as I can see. Do get any error?. Also is pin 5 on the LCD connected to pin 1(gnd)? Have tried to insert some breakpoint so you can trace the data changing. I guess you have some sort of measuring equipment like a volt meter, or a scope
Message 19 of 21
(1,726 Views)
also do your PC and LCD module share a common ground. You have to connect some of ground signals on the PC LPT port to the LCD ground
Message 20 of 21
(1,724 Views)
