Labview control of Zaber Traverse
I am using a traverse system by Zaber to traverse an area and collect some data. I am therefore trying to track the position of my Zaber linear stage on Labview so that I can know the position it is in at every interval data is collected.
Does anyone know how to continuously track its position? I can only get the traverse to output its position after a move request but would like to know exactly where it is at all points in time.
Please help!
Thank you.
Message 1 of 10
(6,899 Views)
I can think of two options for tracking position in LabVIEW while a Zaber device is moving:
1. Send the Return Setting command with 45 (Current Position) as the data value while the move is executing.
2. Change the device mode to send Move Tracking updates while the move is executing.
The two commands are described here:
Both of these options mean that you won't be able to use the simple request/response pattern when communicating with the device. You may need to put some timeouts or sanity checks in your routine in case a response gets lost. Here's some pseudo-code of my suggestions for how to implement the two options:
1. Using Return Setting command:
Write Move Absolute to target position x.
(Note that it's Write, not Request)
Begin Loop
  Request Return Setting 45
  get position from response and log/display it
  check command from response
Loop while command is Set Current Position (45)
ReadBlocking one more response
When the move finishes, you should receive a response from the Move Absolute command. You could also end the loop when the position reaches x or when the position stops changing.
2. Using Move Tracking mode:
Request Return Setting for device mode
Set bit for Move Tracking
Request Set Device Mode
Begin Loop
  ReadBlocking a response
Loop while command is Move Tracking
Set device mode back?
The first option is more flexible if you want to use a timed loop to control how often you read the position. I think the second option is simpler, but you do have to change the device mode.
Message 2 of 10
(6,882 Views)
Dear Don Kirkby,
Thank you very much for your response. It is very useful.
I do not fully understand the difference between Write and Request, could you explain that further? I am also confused as to how you get the values reported back to the computer when you are either using Manual Tracking or Move Tracking.
Any more information would be greatly useful.
I have attached the code that I am using so far.
Fred
Message 3 of 10
(6,839 Views)
Write just sends a command to the Zaber device and doesn't wait for a response. Request sends a command and then waits for a response. When the move tracking is turned off, Request works well because the device doesn't respond until it finishes moving. When move tracking is turned on, Request isn't really useful, because it sees the first position update and thinks the move is finished. Instead, you can use a Write followed by a loop that uses Blocking Read and loops until it sees the final move response.
There's a brief description of all the instrument driver's different VI's here:
http://www.zaber.com/wiki/Software/Labview_Driver#VIs_included_in_the_driver
You can also look at the documentation in the VI's themselves.
Message 4 of 10
(6,822 Views)
Thanks again.
I have been looking closely at the Write commands and read responses example VI on the link you posted but am facing a few issues. How would you include a time for each response out, would it be possible? And also how would you provide a series of write commands one after another?
Message 5 of 10
(6,794 Views)
I can think of two ways to add a time stamp to each response out:
  1. Use a separate array of time values. The nth entry in the time array corresponds to the nth entry in the response array.
  2. Create a new cluster type with the time values and whatever fields you need from the response. As you receive each response, copy the fields plus a time stamp into the new cluster. Be careful with your time stamp though: if you have a clock in parallel with your request block, it may record the time you sent the request, not the time you received the response. It might be easiest to write a sub VI that takes in a Zaber response and then outputs your cluster including a time stamp. I'd recommend this technique over the separate arrays because it would be pretty easy to get them out of synch with each other.
To execute a series of write commands, you can either specify them all individually like we do in the example, "Zaber Beginner - Send a List of Commands" or you can specify them in an array and loop through the array like we do in the example, "Zaber Expert - Enter a List of Commands". Those examples both use Request, but you can use Write instead if you need to. Just don't send multiple move commands to the same device with Write, or the first move won't have time to finish.
Message 6 of 10
(6,788 Views)
Thanks again.
I need to send a list of multiple commands with Write, how to I avoid the traverse not finishing the first command before starting the next etc? You mentioned something about Block Read. How should that be used?
Message 7 of 10
(6,779 Views)
The easiest way to wait for the movement to finish is to use the Request Command VI instead of the Write Command VI. The Request Command VI does three things:
1. Call Write Command VI. This sends the command out the serial port.
2. Call Blocking Read Response VI. This waits for a response from the serial port.
3. Check the response to see if it's an error response.
Request Command VI is the VI you should use most often. The only time to use the Read and Write VI's is when you want to send more requests while a move is still executing. If that is what you want to do here, then you can look at the Zaber Expert - Simultaneous Requests example to see the Blocking Read Response VI in action. You can also look inside the Request Command VI to see exactly what it does.
If you're still trying to implement the position poll that we discussed at the start of this thread, then you want to use Write for the move command and Request for all the Return Current Position requests. You use Blocking Read at the end of the loop to scoop up that one last response that's sitting in the serial port. This works because you're not sending multiple move requests. The Return Current Position requests don't interrupt the move request.
Message 8 of 10
(6,767 Views)
Hi guys,
I'm using 4 Zaber linear actuators to move 2 antennas on a XY plane. I can't reach this two goals:
1)tracking exactly the two antennas to preview their collision
2)move (absolute or relative) with a lower speed
Does anyone could help me?
Thank you all!
Stefano
Message 9 of 10
(6,368 Views)
Are you trying to track the devices' positions while they move, Stefano? If so, I described three options on stackoverflow.com.
  • Interpolate from the start and end points.
  • Poll the position using a timer.
  • Turn on a device mode that reports the position every 250 ms.
You can change the movement speed using the Set Target Speed command. You can find a list of all the commands and settings for each device in the user manuals.
yours,
Don Kirkby
Zaber Technologies
Message 10 of 10
(6,359 Views)
