Labview control servo motor & DRIVE
Hello all ,
i am new to servo motor control with labview
 i have a Mitsubishi servo drive ( MR - JE -40 A  SERIES ) With servo motor interfaced
  i would like to control ( communication ) using labview
In that servo drive having the RS 485 port . so i am using the RS 485 to RS 232 converter to my PC
by roughly  i have designed a small code only for checking the communication ( modbus )
parity and flow control are there .?  which mode i have to use ? ASCII or RTU ?
Guide me  and post your views
(5,600 Views)
感觉应该是modbus rtu ,以前用过三菱的变频器E700,就是支持modbus rtu
(5,582 Views)
Were you able to communicate and control servo drive using modbus. I am also working on same Mitsubishi servo drive ( MR - JE -40 A SERIES ).
(5,018 Views)
yes Pradeep ,
we can communicate with that by writing the commands . by joining the numbers ....
Read that manual . In that they mentioned  the commands for each operation
Try for Jog , Forward , reverse first .
(5,011 Views)
Thanks, actually I am having counter counts as a input to servo and the servo should turn that much turns to reach the destination...if possible can u share vi snippet...
(5,001 Views)
hello budy
can you give a vi that communicate on command basis
(2,756 Views)
Try using RTU-manual. I believe this is what the user manual is suggesting.
(2,731 Views)
