Labview controlling Teststand using the API
Hello All,
As part of a larger project I would like LABVIEW to remotely drive Teststand possibly using the API. The functionality I need is: Execute Teststand, Pass the Sequence Path/Name, Login, Execute the sequence, close Teststand.
I had been using the SystemExec (CMD line) with a long string but cannot find a command allowing me to login, so Teststand halts at this point.
If there are any suitably simple examples using the Teststand API technology I would appreicate a few pointers.
Chris
(3,247 Views)
From your description it sounds like you want a LabVIEW operator interface. Earlier resource here.
TestStand ships with 2 example LabVIEW operator interfaces.
Hope this helps.
Now Using LabVIEW 2019SP1 and TestStand 2019
(3,237 Views)
