Labview conversion from Le croy to tektronix Oscilloscope
Now that is a rude repy! I wasn't assigned to do the project as I have no time to waste on programming that is a very small part of my real experiment! yes I'm looking for a fast way to solve it not an easy way! so please if you don't have a helpful reply then keep it to yourself!
Message 11 of 15
(657 Views)
You have not time to waste on programming?
Then you will not be able to use the LeCroy then.
Message 12 of 15
(644 Views)
To use Signal Express, you want to look for IVI drivers for the scopes. That will allow you to use a scope from any vendor without changing the program.
It sounds like Signal Express is actually a good choice for you.
Message 13 of 15
(630 Views)
I will actually- so you Mr. I know everything basically knows nothing Smiley Tongue
Message 14 of 15
(619 Views)
Thanks! sounds like a great/smart solution for now!
Message 15 of 15
(618 Views)
