Labview crash on lvdaq.dll
Labview 7.1 crashes when dropping any Traditional Daq on diagram. Traditional daq version 7.3.
Mass compile crashes when lvdaq.dll is displayed, have removed and reloaded traditional daq
Any ideas ?
thanks
Mike
(2,927 Views)
Hi Mike,
Thank you for posting to the NI Forums! I have searched out database and have not found any reported issues with Traditional DAQ causing LabVIEW 7.1 to crash. Traditional DAQ version 7.4.4 is the latest version that is compatible with LabVIEW 7.1 I would recommend upgrading to this version to see if this fixes the problem. Be sure to read the readme for this version of Traditional DAQ as there are some specific installation instructions. Hope this helps! Let me know!
Margaret Barrett
Digital Multimeters and LCR Meters
(2,899 Views)
Found that if I disconnect the Computer from the network, I can then load the vi which is a bit of a nuisance. I can then reconnect the network and then run the vi.
The vi uses a daq card on a remote machine using  "Remote Device Access Server"
If I remove the DAQ card from Measurement and Automation the vi will also load without a problem but of course will not run.
I did switch to Traditional NIDAQ 7.4.4 but it did not make a difference.
(2,781 Views)
