Labview crash while exe build
Hello All
When i try to build application i found this error.
Please find the crash report in attachment
Please give me solution ASAP. I am stuck in project delivery.
(2,351 Views)
In the debug log you posted there's a ton of messages about the report generation toolkit having bad VIs in it.  Any chance you might have had an update to the Office software on your PC since the last successful build?  That might have made them stop working and could be to blame for a crash.
Also, any chance you have the Viewpoint TSVN Toolkit installed on your PC?  It seems to break builds using LV 2014.
https://forums.ni.com/t5/LabVIEW/Building-Installer-Crashes-Developement-System-LV2014SP1/td-p/31336...
(2,326 Views)
How can i resolve this ?any suggestion?
(2,320 Views)
@parmar483 wrote:
Hello All
I can't give you solution.   I can provide some things to try.
  • Clean the Build. Just right-click the build spec and choose Clean Build.   With 2014 this sometimes works out.
  • Clear the object cashe and resave the project.  Again, with 2014 ..... wonderful things 'might' happen.
  • "Floss" your project!  How nasty are the dependencies? You haven't shown even a screenshot of the lvproj file.  Again, you are using old software  without any patches...why ?
  • Apply the 2014 f2 patches...  or at least read the release notes!
Post something more useful than a error message screenshot.   How big is the project?  What is in it?  Where did it originate? What SCC provider/how many developers?
Blind surgeons rarely a first choice.
(2,318 Views)
Actually the TSVN TK is a great clue .
As is the information about the Report Generation TK.  LabVIEW 2014 did not automatically install the Report Generation TK (unless you bought the developer suite)  since the OP has not used the SSP to apply patches I am assuming that the RG TK may be missing.
(2,312 Views)
