Labview crashes regularly
Every 20 minutes or so my LabView 8.0 just crashes. In the Windows event viewer I get an Event ID: 1000 with description:
Faulting application labview.exe, version 8.0.0.4005, faulting module unknown, version 0.0.0.0, fault address 0x00000000.
And usually this is followed by an Event ID: 1001 as follows:
Fault bucket 234322389.
I already searched the NI-website and the Windows website but without much success...
Does anyone have an idea what causes this behaviour?
Thanks for the help.
Laurent
(2,873 Views)
Hi, Laurent.
Thanks for sending us that event information. It's usually a helpful debugging method, though it doesn't seem to have helped us much in this particular instance. 😃
Can you tell us a little more about the crash? I have some questions for you:
Do you get the standard Windows XP "This application has encountered an error" message? Or does LabVIEW hang? Or does it just disappear?
Does this crash only occur when you're editing the same VI, or does it happen regardless of what VI you're viewing?
Does it happen 100% of the time?
Has this installation of LabVIEW always done this, or is it a new problem? If it's new, can you tell me what changes might have occurred on the PC around the time the crashes began? (Even if seems unrelated, it may help.)
Have you tried uninstalling and reinstalling LabVIEW? I know that can be a lengthy process, so you may want to answer my questions above first before you try that. (Perhaps one of your answers will suggest something else to try.)
Regardless of the cause, I'm sorry you're encountering this crash. I know that can be very frustrating!
Have a nice weekend.
Sarah K.
Search PME
(2,848 Views)
