Labview crashes
Hi..
When i try to add a SolidWorks assembly to the project explorer, Labview just shots down without any warning.
I´m running SolidWorks and the assembly I want to add to Labview when I´m trying to do this, but after a few seconds Labview just shots down without any warning.
I can open other examples with SolidWorks assemblys in them and I can open the assembly in SolidWorks, but when I try to deploy I´ll get this message "The deployment connection has timed out.", and if I try to "change motion study" or "map sensors" Labview will just shote down without any warning.
Help Please.
I´m using:
Labview 2009 SP1 Professional Development System
SoftMotion 2009 SP1 Premium
SolidWorks 2010 SP5.0 Education Edition
I´m Running Windows 7 (32 Bit)
(3,980 Views)
Hi, Druedahl, have you sorted it out? I got the same problem, only difference is my OS is windows XP.
(3,950 Views)
Maybe the Solidworks should be premium or professional version? Any NI expert can help it out?
(3,940 Views)
It works now after I installed Labview 2010.
(3,911 Views)
My problem was that I had both SoftMotion 2010 and 2009 SP1 installed which involved an collision. After I uninstalled SoftMotion 2010 it worked fine.
(3,896 Views)
