Labview crashes
I am trying to control a step motor from usb by using imported dll. VI works in one computer and closes itself in an anotherone at the end of operation. Attached is the log file.
Regards
(4,109 Views)
Log doesnt help. Can you post your VI ?
Kudos are always welcome if you got solution to some extent.
I need my difficulties because they are necessary to enjoy my success.
--Ranjeet
(4,106 Views)
Did you send the automatic crash report?
How different are the two computers?
(4,101 Views)
I thought you are using .dll from the folder other than C:\Windows\..
Some days before i was using USB webcam to control through LabVIEW using User32.dll, despite of using the C:\Windows\System32\User32.dll i choose the dll from different location. This leads Crash LabVIEW so i put only User32.dll name inside the Call Library function path (http://screencast.com/t/5SUbCP1SzW).
I think this will help you to debug in some way.
(4,084 Views)
Attached are the vi's and dll file that I created the sub vi's.
- Processors and Ram are different one with 16 GB ram the other is 8GB ram and so on. But this shouldn't be a problem.
(4,080 Views)
