Labview display conx lds autocollimator
Hello, Im working on a motion system and i have to do an automatically test for accuracy position.
Do you know if i can have the conex lds autocollimator's display on labview?
I didn't find it on the library.
Thank's
(639 Views)
According to the documentation you can do 2 ways:
1- read/write RS422 commands to the equipment ( you will need to use VISA serial commands)
2. Create Calls to DLL
for this you will need to use CALL LIBRARY FUNCTION
double click and it will open  a window, where you indicate where the dlls are installed and call them according to the documentation (CONEX-LDS Command Interface Manual)
(602 Views)
I didn't find the library can you please give it to me please. If there is one.
(590 Views)
