Labview distributable application with professional data reporting
Hi there,
I'm searching for the right approach to solve the issue I'm facing using the standard report generation VIs in Labview.
Even if the report is a quite simple ensemble of text / charts / tables, the report output is very poor quality. Exporting into excel / word isn't a good solution since the distributable has to be installed onto customers PC, and having Office installed isn't under my direct control... and this is a good things...
I've tested Diadem and the report output is good, but having 1000€ additional license on each customers PC just to have a PDF printed isn't a clever approach.
Could Crystal Report be a solution?
Any other suggestion well accepted...
(4,688 Views)
Accepted by topic author sciawatt
(4,671 Views)
Hy JM,
Thanks, I'll give a try during Christmas vacation, thank you.
Anybody knows if Crystal Report is a viable solution?
(4,655 Views)
Dear Jean Marc,
I tested your Exaprom PDF toolkit and so far it does everything I need... Excellent! Smiley Happy
Many many thanks .
(4,336 Views)
Hi Jean Marc,
Thanks very much for your pdf application that I find very interesting.  I tried to use it, but being a newbee to pdf I couldn't get your program to do what I need.
Do you have a simple example about how to print an excel table to a pdf file without any complicated stuff around it.  It would also be ok to just print a simple labview table to a pdf file.
Your help will be greatly appreciated and thanks in advance.
(2,887 Views)
