Labview driver for Newport ESP301.
Message 11 of 30
(4,245 Views)
Hi cbutcher!
When I was trying to read the position of the stage by using the following program, there was an error saying something wrong in the Write Command and Read. Do you know what is going on here? Thanks!
Message 12 of 30
(4,238 Views)
Without hardware, can't be sure, but looks like maybe the Write Command and Read (sub)VI is not sending a properly formed command. Usually this involves the wrong or missing termination characters.
Double click down a few layers on Initialize.vi (follow the error call stack) and see where the termination character is added, then check it matches the documentation available for the ESP301.
GCentral
Message 13 of 30
(4,226 Views)
Hi cbutcher,
I have developed the labview program for ESP301 and it is working in one of our PC (test PC). However, when I was trying to transfer everything to another PC (LAB PC), which is in our lab, I run into a problem, shown below. I am wondering if you know how to solve this error? I search online and tried some methods but the it's not resolved. Thanks!
Message 14 of 30
(4,207 Views)
Hi  cbutcher,
We are using RS232 instead of USB cable now, and labview program can control ESP301 now. Thanks!
Message 15 of 30
(4,198 Views)
Dear ,
         Could you help to share the LabVIEW drivers of ESP301 here?
Message 16 of 30
(3,960 Views)
1. Download ESP301 Labview driver (version 2010), ESP301 Firmware Installer and ESP301 Utility Installer Win32 from ftp://download.newport.com/MotionControl/Current/MotionControllers/ESP301/Archive%20Software/Labview...
Message 17 of 30
(3,953 Views)
Accepted by topic author Max999
The pictures attached below are the manual of how to write a Labview program to control ESP301. Hope it helps!
Message 18 of 30
(3,791 Views)
Hi, I got a pretty naive question, when I followed your step, I found that I am not able to open the ESP301 Firmware after updating it, I tried both RS232 and USB, after updating, the program will shut down itself, and when I opened it again, It just kept updating again. Could you please give me any suggestion about that? or can you show me what the interface looks like?
The ESP301 Firmware program is downloaded from here https://www.newport.com/p/ESP301-3N, I am also wondering if you have any other sources for that?
I will really appreciate if you can help me with that.
Message 19 of 30
(3,677 Views)
I am not sure what is the problem of your case. Message 18 of 19 is our final solution.
Message 20 of 30
(3,672 Views)
