Labview driver (or GPIB commands) for AQ3540 Optical channel Selector
Can any one tel me were can I find Labview driver (or GPIB commands) for AQ3540 Optical channel Selector?
Thank's,
Shay
(3,209 Views)
Hello Shay,
As for commands, they would probably best be found in a user manual for the device.  Have you contacted the manufacturer to see if they have an instrument driver?
It will take some time, but you can also request an instrument driver at the following site: Request Instrument Driver.
Angela
(3,197 Views)
As for now, I did succeed to communicate with the device and send it the important commands,
Thanks for your reply.
Have a best day!
Shay
(3,190 Views)
Hi, I also would like to have the labview driver to control the AQ3450. May you share your driver with me? Thanks! Chunhua
(2,733 Views)
Greetings Houstonspring
This is an old thread. In case you don’t get an answer, I would suggest you send commands to your instrument manually through GPIB functions in LabVIEW. These resources may prove useful to you.
Warm Regards,
Luis J.
(2,710 Views)
Do you have the manual? That should be your first step.
(2,704 Views)
