Labview drivers for Omega OM-DAQ-USB-2401
This DAQ is a thermocouple/voltage input USB device. Omega does not provide Labview drivers for it, but it does have .NET/API drivers for Visual Basic, C#, and Visual C++. Has anyone been able to build a driver for this device in order to get measurements from it in Labview? I've read the USB Instrument Control Tutorial, but am not sure if this would be of any help with this type of device. I simply want to use the DAQ output (voltage measurement) as a variable in Labview to control other devices with an NI 9472.
Message 1 of 12
(6,635 Views)
I have not used these specific devices, but I have used a lot of Omega product in the past and they tend to sell good stuff. They do have a tendency to resell a lot of stuff too. So one thing that might be worthwhile is to see if this box is really theirs or if they are reselling hardware from somebody else.
Having said that, give the .net a try. The examples in the other languages should give you the basic flow of what calls you need to make to accomplish common tasks -- like reading a value.
Mike...
PS: it also might be interesting to plug the thing in to your computer and after letting it load whatever drivers it needs, see what kind of device the OS thinks it is.
Certified LabVIEW Architect
LabVIEW Champion
Message 2 of 12
(6,609 Views)
Hello, I found this messages from 2013 and am wondering if three years later someone already has developed LabView code based on .NET which would communicate with OM-DAQ-USB-2401. Thanks
Message 3 of 12
(6,145 Views)
I'd encourage you to create a new forum thread to get more exposure. Check out NI Discussion Forums User Guidelines #3
Message 4 of 12
(6,107 Views)
Hi Leonid0813,
It has been 7 years now and I am wondering the same thing. Did you find the solution yet?
Message 5 of 12
(4,718 Views)
We have developed custom dll instead of LabVIEW application. We call dll functions from either LabVIEW by using "Call Library Function Node" or from Test Stand call dll module.
If any interest I can share the dll
Thanks.
Message 6 of 12
(4,711 Views)
Yes, that would be of great help.
Do you perhaps have an example panel (.vi), where you make use of the "call library function node"?
I am not to familiar with .dll and the .net framework.
Thanks in advance!
Message 7 of 12
(4,692 Views)
I don't have LabVIEW example handy at the moment as this have been 7 years and I changed my laptop since then.
Also most of our work is with Test Stand where LabVIEW is optional, i.e we just call dll into the sequence and select functions to be executed in particular steps.
I have attached the dll to this post.
Thank you
Message 8 of 12
(4,681 Views)
I found all components necessary to recreate LabVIEW library and was able to generate it. The testing would be your job, but decent library is created and attached.
Thanks.,
Leonid.
Message 9 of 12
(4,673 Views)
Thanks for the files, I really appreciate the help.
However, there seems to be a problem with the .dll and the labview library.
I think it has to do with the architecture of the .dll (32 or 64 bit?).
I run Labview 2016 32-bit on a x64 windows system.
I am able to open the VIs in the folder, however I am not able to run them.
I get the following error:
LabVIEW: (Hex 0x5ED) An error occurred in the Call Library Node processing. This error was most likely a configuration mismatch between the calling conventions of the Call Library Node and the function being called in the DLL.
Also I do not know what is meant by the input vi (integer) in all the functions.
Best,Luuk
Message 10 of 12
(4,610 Views)
