Labview dsc client server
I use LV7 and labview dsc.
I would like to read historical traces from a client PC. my database is saved on a server PC. I'm using "Read Traces.vi". It works well but i have to wait 10 or 20 seconds to have results (for only 100 points).
I have no problem for reading tags in real time but it is very too slow for reading historical data.
I would like to know if there is a solution to minimise time for echanging historical data.
Thanks.
Alexis de la fontaine
SECMAI
(2,930 Views)
Hi Alexis,
Are you observing the same delay with Read Traces.vi when you read traces locally? 100 points means 100 I/O points (tags) ?
Remzi A.
Applications Engineering
(2,930 Views)
