Labview embedded ARM SPI interface for MCB2300 boards
I am trying to program SD card using labview embedded module. I have MCB2300 board (ARM 7). Is there any example VIs to program SD card using SPI interface ? Any ideas to do it.
Arun.
(4,128 Views)
Hi Arun,
Currently, we dont have any examples for SPI. But I will try and get you some help on this.
-Jaidev
Senior Product Manager
(4,062 Views)
Thanks Jaidev.
(4,054 Views)
Hi Arun,
This should help you a little:
http://www.keil.com/mcb2300/mcb2300-schematics.pdf
The data sheet shows a Pin description in section 6.2. The SPI pins are of course muxed, but it looks like they are all reachable:
pin 86: MOSI
pin 87: MISO
pin 89: SCK
pin 90: SSEL
TO program in LabVIEW, you can use the SPI VIs that are included in the module.
-Jaidev
(4,040 Views)
