Labview error -1907 (sound and vibration)
I am trying to measure two analog inputs(NI-PXI-4461) using daq assist on Labiew 7.1. I want to run the same code on both inputs and comparing them together on a graph. I am measuring 2 accelerometers and the most important parameters are measuring the g rms and phase difference. I keep getting an error code -1907 "The sampling frequency of the input waveform should be greater than 0 (dt greater than 0)." I have set the sampling freq to 2k. I am not sure what I am doing wrong. Any help will greatly be appreciated.
SparkEE
(4,315 Views)
Accepted by topic author SparkEE
Hi SparkEE,
Playing around with your code with a simulated device, I noticed that the output from the DAQ Assistant gets lost when you use the 'Convert from dynamic data' block.  I checked this by placing waveform graphs before and after the block.  If you look at this block, there is a 'channel' input.  I wired this to the iteration terminal of the for loop (so now it specifies channel 0 then 1) and this seems to have resolved the error.  Can you give this a shot?
Jon F.
Technical Support Engineer
(4,252 Views)
AirFrantz, you are the bomb!!!
(4,243 Views)
