Labview error: Fatal Error : "eventoracle.cpp" at line 370
Hi All,
We are developing an operator Interface in LV 7.0 for TS 3.0. The operator interface some times hangs by displaying ,"Labview error: Fatal Error : "eventoracle.cpp" at line 370.". Once we press ok, LV is terminated.
Whenever it hangs, i could see that the CPU usuage was 100%. Someone please help us to resolve the issue. Thank you in advance.
Sas
(2,821 Views)
The eventoracle.cpp error has been reported earlier to National Instruments. If you could attach an error log file with your post, I will pass on the file to our R&D group. Though we might not be able to give you an immediate fix, we would work on making the next release of LabVIEW better so it would not crash with eventoracle.cpp error. Also it would be great if you could give us some specifics on what causes this error.
Ankita A.
(2,797 Views)
Hi ,
Thank you for your quick reply. This error is kind of random and we dont have the log file right now. Next time when we face this error, we will log it and send to you.
Thank you
Sasi
(2,784 Views)
