Labview error -linkageIncompleteError
I am using labview 2019 and Teststand 2019.
When I set the adapter in teststand to Runtime I get following errors.
linkageIncompleteError: "cannot report callers without a VILinkObj";
The whole project works fine in development version.
The Labview project and the Teststand sequence files are also error free.
I am adding the log file generated herewith.
Any suggestions for a solution for this problem?
Best,
Akshay
(2,465 Views)
Hii,
Well what I found is that I am using Private  VI's in my project and building a "LVLIBP" , the labview runtime has problem opening these Private VI's and .ctl files.
Has anyone faced similar issues and is there a solution ?
Changing the provate to Public is not a workaround for me.
Best
Akshay
(2,446 Views)
"Private" means "private".  That's it.
Bill
CLD
(Mid-Level minion.)
(2,440 Views)
hi,
The issues is if NI knows this , and still does not provide a solution .
whats the point in providing Private scope if we can't use it in Runtime  ?
(2,430 Views)
@aparab wrote:
hi,
I think you have it backwards.  Why make it private in scope if you want to expose it publicly?
Bill
CLD
(Mid-Level minion.)
(2,419 Views)
