Labview error: property node, node not supported in current target. How to solve it?
I am designing an interface and would like to add some buttons to call some subVIs.
However, when I used property node and invoke node, the labview show errors. It displaies that "property node, node not supported in current target". The similar error exists for invoke node. I chose the two nodes from the function in mobile porject mode.
I would like to ask why it can not be used in mobile project but it exists in funciton.
I used Labview 2009.
Thank you!
(3,891 Views)
Can you post your code so we can take a look at what you are doing?
Tim
GHSP
(3,872 Views)
Have you checked the documentation? There are some properties and methods that are simply not available with certain targets, especially with a mobile target. For example, there are several controls that are not supported by the mobile module, so it's not that far-fetched to think that certain properties and method would simply not be supported.
(3,853 Views)
