Labview exe (2009) does not run automatically when opened
You need to design your program as a proper state machine. One state could be an idle state. It should always run.
"continuous run" mode is a debugging tool and no sane way to run a VI, especially not a built executable.
Message 11 of 13
(810 Views)
@chethanchandru wrote:
After  setting run when open setting its works only for single run we required automatically continous Run
You probably should make your own thread.  This isn't the same issue the original poster had.  You just need to understand loops.
Message 12 of 13
(795 Views)
Is it possile you have debugging checked with wait for debugging checked? This happened to me once.
Message 13 of 13
(663 Views)
