Labview.exe hangs when starting.
I recently installed LabView 8.0.  It worked whan I initially installed it, but now when starting the program it hangs and will not load.  I have seen the following errors in the Windows event viewer.
Event Type: Error
Event Source: Application Hang
Event Category: None
Event ID: 1001
Date:  1/23/2006
Time:  9:55:37 AM
User:  N/A
Description:
Fault bucket 232191259.
For more information, see Help and Support Center at http://go.microsoft.com/fwlink/events.asp.
Data:
0000: 42 75 63 6b 65 74 3a 20   Bucket:
0008: 32 33 32 31 39 31 32 35   23219125
0010: 39 0d 0a                  9..
Event Type: Error
Event Category: (101)
Event ID: 1002
Date:  1/23/2006
Time:  9:55:27 AM
User:  N/A
Description:
Hanging application LabVIEW.exe, version 8.0.0.4005, hang module hungapp, version 0.0.0.0, hang address 0x00000000.
Data:
0000: 41 70 70 6c 69 63 61 74   Applicat
0008: 69 6f 6e 20 48 61 6e 67   ion Hang
0010: 20 20 4c 61 62 56 49 45     LabVIE
0018: 57 2e 65 78 65 20 38 2e   W.exe 8.
0020: 30 2e 30 2e 34 30 30 35   0.0.4005
0028: 20 69 6e 20 68 75 6e 67    in hung
0030: 61 70 70 20 30 2e 30 2e   app 0.0.
0038: 30 2e 30 20 61 74 20 6f   0.0 at o
0040: 66 66 73 65 74 20 30 30   ffset 00
0048: 30 30 30 30 30 30         000000
(3,955 Views)
Is it possible that you may have downloaded a   30 day trial version and now 30 days have passed?
Ankita
(3,938 Views)
Anita, Thanks for your reply. I just installed LabView five days ago, so I do not think this is the problem. Also, I am pretty sure I installed the full version. At least that is what we paid for. rlk
(3,922 Views)
Hey,
If you are not experiencing problems with any other software but only LabVIEW, I would suggest uninstalling and reinstalling LabVIEW.
Ankita
(3,903 Views)
Ankita,
I have it working now. I had to uninstall thru the control panel, but also remove any Labview folders to make it work. Once I did that and reinstalled it is working again.
Thanks for your help.
rlk
(3,877 Views)
