Labview for laser control
We have a Thorlabs MCLS1 laser source.
We need a program that runs for 50 days, starting and stopping every 12 hours.
Measuring The sequence where it is on takes 3 minutes. (LabVIEW starts MCLS1 every 12 hours and stops it after 3 minutes)
Can LabVIEW do that for us?
We have a student trial version of the program to test it out.
So, we were wondering if there were any limitations on the trial software.
Sequence:
Start
Measure for 3 minutes
Stop
Rest for 12 hours
Start up again
Stop
Rest for 12 hours
Repeat.
It would be appreciated if you could get some tips to achieve this.
(2,266 Views)
Hi pynttari,
@pynttari wrote:
We need a program that runs for 50 days, …
Does the trial period even last for those 50 days?
When you want to automate your testbench you should use a valid license…
Well, LabVIEW can do that…
What about creating a program to run for just those 3 minutes and have it exit then? Use Windows capabilities to start that program each 12 hours!
(2,257 Views)
LabVIEW is a very rich programming Language and (with sufficient programming skills) a LabVIEW program can do anything you want it to do, no matter how complicated!
I am not sure what a "student trial version" is. can you explain. Any LabVIEW version type is available as trial and will stop working once the trial period ends. What LabVIEW version do you have? A long time ago, there was a free LabVIEW student version (to be used for personal studies) for students that could be renewed as long as you are a student. AFAIK, this is now replaced by the community edition.
Unless this is a K-12 school (you did not say!), be aware that if your programming is used for academic research or as requirement for your study, you cannot use the community edition and your campus should give you the required license (details).
(2,225 Views)
