Labview for ni crio-9038
I have a ni crio-9038 bought in 2018 and I have to buy a computer to install labview and the drivers to operate it. I wanted to ask for a confirmation that, although it was bought some years ago, it will work with the software versions I found online (https://www.ni.com/en/support/downloads/drivers/download.ni-compactrio.html#564323) and with 64-bit windows 10 or windows 11. I put a picture of the modules I am using with it in case it is relevant.
Thanks a lot in advance!
(505 Views)
You can check compatibility between various NI software and their hardware here: https://www.ni.com/en/support/documentation/compatibility/09/software-support-for-compactrio--compac...
The 9038 is part of the 903x series which is still available but expected to have an EOL at the end of this year. That doesn't mean it will stop working then if you already have one, just that in a few years from now, new NI software will not support it anymore. But until then you are safe with your controller and even after that happens, you can always use a previous version of NI software that still supports it (until that version won't work on your new Windows .Net Super Duper version that Microsoft will eventually release).
Rolf Kalbermatter  My Blog
(489 Views)
