Labview freezes when starting VIs
I am experiencing a problem with LabView 2011 under Windows 7. The problem is, While a number of VIs are working, Initiating a new VI will cause LabView to freeze for seconds before every thing goes back to normal. If lucky, the freeze is short so not to lose data but in many cases it is long enough to lose the data. This behavior is not associated with a certain Vi. It happens at random. In fact, sometimes, changing a control value on one of the working VI will cause the same thing. To make things worse, sometimes the freeze last for ever and a restart is a must. You can imagine how depressing is that. I had a fantastic experience with LabView 8.6 but 2011 is a pain so far. I am using 6 core PC with a 12 GB RAM.
I hope I am missing something trivial and that the solution is simple.
Thanks in advance
Message 1 of 15
(5,591 Views)
Are you running LV11 SP1? there may be some patches that need applying, check in your NI update service.
CLA | CTD
NI Alliance Partner
iLV Test Solutions Ltd
Message 2 of 15
(5,559 Views)
hi,
My labview is up to date.
Message 3 of 15
(5,555 Views)
Hi i am also using labview 2011 & window 7 but having only 2GB ram & it works fine.
There is something else may be some patch or installtion problem.
The best man to solve this is NI
Kudos are always welcome if you got solution to some extent.
I need my difficulties because they are necessary to enjoy my success.
--Ranjeet
Message 4 of 15
(5,530 Views)
Are you using a decently large project? I'm suspicious of the project environment.
/Y
Qestit Systems
Certified-LabVIEW-Developer
Message 5 of 15
(5,511 Views)
it is closer to be large than small. But, I doubt it is the project. The LabView 8.6 version of the project worked fine. We just updated the project to 2011. I think that LabView dedicate all resources for the new VI on the expense of the running Vis. Any Idea how to check that.
Message 6 of 15
(5,501 Views)
Did you try to mass compile your project?
Message 7 of 15
(5,490 Views)
A couple ideas pop into my mind:
  • Did you mass compile the code into 2011 or are the vis saved in 8.6?
  • Are you making extensive use of queues or .ini file functions?  These changed radically between 8.6 and 2009 and the compatablity (Legacy) vis may be problematic.
Message 8 of 15
(5,487 Views)
Have you read the upgrade notes?  Particularly the part about VI conversions?  Hopefully it's that simple...
[edit] guess I'm late to the party.  😉
Bill
CLD
(Mid-Level minion.)
Message 9 of 15
(5,484 Views)
Hi
I work with Agilent E4980a.
When I use AgilentE4980a Agilent E4980 measurement.vi example I have following Errors.
Error -1074000000 occurred at Agilent E4980.lvlib:Error Query.vi
Possible reason(s):
Instrument reports:
-109,"Missing parameters"
+0,"No error"
Complete call chain:
     Agilent E4980.lvlib:configure list sweep.vi
Would you please help me?
Thank you
Message 10 of 15
(5,480 Views)
