Labview from C/C++
Hi
My question is about how to call Labview VI/Global variables from C/C++.
We have a cRIO-9012 that runs under the VxWorks operative system.
Up to now, we were calling C functions from Labview, but we also need to
do the opposite.
- Can I call a VI from C/C++?
- Can I access Labview global variables from C/C++?
- Or is there a passive diagram, mapped to a C function, to be placed in
a VI that is triggered by the C function?
Alain
_________________________________________________
Alain Migeon
Please reverse alain and migeon for replying.
(3,311 Views)
Alain,
there are several ways to solve this. So i better start by telling you, what you shouldnt do (because its impossible or not recommended):
- LV does not have the possibility to directly create a shared memory. All ways how you might do this are not recommended.
- You cannot call a VI directly from C/C++. Nevertheless, you can use VI-Server to do this (kind of ActiveX-programming). But this is not the way i would recommend you to do it....
So what can you do:
- Convert your VIs to a DLL and call it from C/C++ (maybe not good for you because of architectural settings)
- Use datasharing with mechanics accessable by all programming languages: TCP/IP, UDP, files, ...
The last thing i mentioned is the one i recommend you, but dont forget to evaluate speed and data-security...
hope this helps,
Norbert B.
Norbert
Expert: Geometry
(3,302 Views)
On Oct 15, 9:20 am, Alain Migeon <migeon.al...@tdcspace.dk> wrote:
> Hi
> do the opposite.
> Alain
> Alain Migeon
The two main methods for accessing the functionality of a Labview VI
from external C/C++ code are ActiveX and Application Builder. ActiveX
is available only on the Windows Platform. Application Builder comes
with the Professional Development version of Labview and can be
purchased as an upgrade for the base and full development versions of
Labview for US $1000.00. A third possibility is to use LabWindows
CVI.
Howard
(3,289 Views)
In article <1192462758.143102.214510@q3g2000prf.googlegroups.com>,
hrhan@att.net says...
> > Hi
> > do the opposite.
> > Alain
> > Alain Migeon
> CVI.
> Howard
Many thanks for the answer.
Alain
Alain Migeon
(3,249 Views)
