Labview hangs for 30 sec after first VI opened
Is anyone else seeing this issue? When I run the Labview development environment and open any VI (including a New VI), I get an hourglass cursor and am locked out of clicking anything for 20 to 30 seconds. I see this behavior on multiple computers. Then I don't see the behavior again while Labview is running.  Pretty annoying!  I'm running Labview 2015 SP1 f10 on Windows 10 or 7.
Thanks.  -Joe Czapski
Joe Czapski, Sonos, Boston, Mass.
Message 1 of 8
(3,402 Views)
As I recall LV2015 was that way, and it was very annoying.
=== Engineer Ambiguously ===
Message 2 of 8
(3,390 Views)
Accepted by topic author Station3
By default, LabVIEW "pre-loads" all palettes in the background, causing this to happen.
Bill
CLD
(Mid-Level minion.)
Message 3 of 8
(3,354 Views)
Thanks, Bill, looks like it was the palettes loading. Under Options I changed from "Load palettes in background" to "Load palettes when needed", and now I don't get the hourglass when I open the first VI.
Now why would "background" loading lock me out of all actions for up to 30 sec? In computing, background processes are supposed to invisibly run without taking too much resources away from the visible apps. Also, I've used the background setting for many years, but the hourglass problem has only recently appeared for me, hmmmm.
Thanks again,
Joe
Message 4 of 8
(3,330 Views)
And for some reason LV2015 was very bad at doing this as I don't recall 2014 or 2016 and newer having that issue..
Message 5 of 8
(3,319 Views)
Yeah, with LV 2014, it only takes a few seconds.
Bill
CLD
(Mid-Level minion.)
Message 6 of 8
(3,307 Views)
Thanks again,
Joe
I don't know why it would for 30 seconds, but I know why it would lock you out while it's loading.  I'm guessing they don't want a user to be opening the palettes while they were still loading.
Bill
CLD
(Mid-Level minion.)
Message 7 of 8
(3,305 Views)
Thanks again,
Joe
Unless they use non-reentrant components that are also not thread safe and require the UI Thread to execute serially 😉
Just saying
A Solid State Hard drive helps a lot.  (I Wish I had one)
Meanwhile loading pallets as needed rather than suffering the cost on launch just pusses the problem out to the first time you hit Ctrl+Space.
Message 8 of 8
(3,299 Views)
