Labview how to realize the first-order filter output
How does labview realize the first-order filter output(damping step change),the blue line is what I want
(841 Views)
Hi hy,
Typically "LabVIEW realizes" what YOU programmed in your VI!
To dampen high frequencies you usually use low-pass filters…
(808 Views)
