Labview implementation of file encryption.
Wanting to encrypt the contents of a file with LabVIEW. Therefore looking
for a LabVIEW implementation of a file encryption algorithm or is there another
wway to do this ?
thanks
derm
(5,907 Views)
I have one available at http://www.cs.wcupa.edu/~tstarn/LabVIEW.html.
It's of my own creation. Not being a cryptanalyst I couldn't tell you
how secure it is but it was fun to make.
> wway to do this ?
> thanks
> derm
(5,907 Views)
> looking
> another
> wway to do this ?
LV has several tools that allow you to mangle files pretty good. I
assume you are working with an ASCII file that could otherwise be read
with a text editor. You can read in the ASCII string, then cast the
string to a different type, swap bytes, reorder the string... you can
implement a fractal folding of the data if you wish to.
No built-in tools, but it's quite easy to create your own. Or just PGP
if that suits your needs.
- andrew johnson, berkeley CA
(5,907 Views)
Hello Diarmid Milligan
Let me share with you some information about files:
https://www.ni.com/en/support/documentation/supplemental/06/the-ni-tdms-file-format.html  (The NI TDMS File Format)
https://knowledge.ni.com/KnowledgeArticleDetails?id=kA03q000000x4PcCAI&l=en-US  (Writing TDM and TDMS Files in LabVIEW)
Webcast Wednesday # 8 | Using TDMS and other file formats in LabVIEW (Webcast Wednesday # 8 | Using TDMS and other file formats in LabVIEW)
Hope this will be useful
Regards
(3,917 Views)
Hi David,
wow, that's what I call "user orientation": answering 17 year old threads! 😄
(Diarmid wrote his question even before he was registered - according to his profile!)
(3,913 Views)
