Labview in c
how can i compile g-language of labview in c or c++?
Thanks in advance.
(3,890 Views)
There is no G to c/c++ translator...and why would you want to do a translation anyway?
When G is compiled (must be done using a G compiler) the machine code produced is more or less as fast as a comparable application written in c/c++.
(3,889 Views)
"Antonello Camiletti" wrote in message news:...
> Hi,
> Thanks in advance.
There is no G -> c++ convertor I know of. However, the application
builder allows compiling of G -> ".dll" , which may then be called
from another language.
(3,889 Views)
Why would you want to compile to C or C++?
One thing I would like to do is write basic LabVIEW code that can be compiled to run on a PIC microcontroller. There is a C compiler for the PIC so thats half the problem solved.
Does anyone know of a way round this?
(3,718 Views)
Have a look at LabVIEW embedded, it runs on many things (but maybe not on a PIC):
Message Edited by altenbach on 02-16-2007 08:51 AM
(3,701 Views)
